Setting channel on a Hub one
FIXEDTopic Options
- My Router
- Re: Setting channel on a Hub one
03-07-2024 5:55 PM
The channel selection on my hub one router is set to Automatic.
How can I set it to manual, so I can choose the channel?
I need to do this because other local networks keep changing their channels and my router ends up clashing.
Cheers
Cheers
Fixed! Go to the fix.
Labels:
Message 1 of 3
(1,134 Views)
2 REPLIES 2
03-07-2024 6:11 PM
Having watched this Plusnet YouTube video - Advanced Set up of your Hub One router
it looks like you should be able to do what you're asking -
03-07-2024 7:27 PM
Thanks....
Message 3 of 3
(1,096 Views)
- My Router
