Safeguard
- My Router
- Safeguard
Safeguard
25-05-2025 10:08 AM
Wanted to block all internet usage from 12 to 6am not just certain sites, dont want to keep turning on and off every night - already in bed by 12 . Plusnet said they cant advise, can be done in this forum maybe someone would tell you how to
Message 1 of 2
(492 Views)
1 REPLY 1
Re: Safeguard
25-05-2025 11:03 AM
@happydays01 you can create a schedule to control wireless access for a group of devices, see https://www.plus.net/help/broadband/router-user-guides/hub-two/
Google 'hub 2 wireless schedule' and I think the AI result is pretty much correct with the instructions ( I dont use a Hub 2 so not absolutely sure!)
Message 2 of 2
(471 Views)
