SRA Enabled or disabled?
DOC1
Hi All
Just a quick question.
Should I Enable or Disable the SRA setting on my router?
5 REPLIES 5
RealAleMadrid
Fixes: 68
Re: SRA Enabled or disabled?
@DOC1  SRA or Seamless Rate Adaptation is not implemented on Openreach FTTC (VDSL2) services so whatever you set it to on the router makes no difference. I believe it is used on G.Fast connections so the sync speed can change up or down without dropping the connection.
DOC1
Sorry for delay in getting back to you .
Ok thanks for letting me know. I just wanted to know if my router is all set up ok.
Browni
Aspiring Hero
Fixes: 61
I can confirm SRA is used on G.Fast.
DOC1
Thanks for confirming that .
Strat
Fixes: 565
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
