How do I update the firmware on my Hub One router?
moonfruit
My Hub One is currently running 4.7.5.1.83.8.217.
What do I have to do to update the firmware to the latest version?
12 REPLIES 12
Fixes: 480
Re: How do I update the firmware on my Hub One router?
@moonfruit  Welcome to the forum.
You can’t update it, it’s done remotely by Plusnet. If you factory reset it by pushing a paperclip or similar in the reset hole and keeping the switch closed by about 30 seconds it will reset itself back to the original settings. If the hub is properly registered in the Plusnet system this should trigger a firmware update in the next day or so. Alternatively you need either a helpful Plusnet staffer to come along or ring in and hope that you get an Agent who understands what you want.
Fixes: 1,662
Thanks for your post @moonfruit and welcome to our Community Forums
That firmware version indicates your Hub One has dropped off the hardware management platform
If you can PM me your username and serial number of the router, I'll be happy to get it added back on
Dhru81
Hi @Gandalf  is it possible to push a router firmware update to my router please. I'm having the same 5ghz issue,
Regards,
Dhru
Fixes: 1,662
@Dhru81 What firmware is your router on?
Dhru81
@Gandalf Currently on 4.7.5.1.83.8.263
Fixes: 1,662
Thanks for the confirmation @Booboo12
You're on the latest firmware version already, we're due to roll out a newer one within the next couple of months to everybody but if you post Here you may be able to jump the queue.
Numlock
Hi @Gandalf, I had problems about 18 months ago and after talking to a Plusnet advisor I replaced my modem with identical Sagecom which my daughter no longer needed. All went well after set up but the software has never updated,  details are ver 4.7.5.1.83.8.237.2.2  last updated 04/11/2017.  As I didn't notify Plusnet of the swop does it need to be added to the hardware management platform?
TheMightyAJ
Fixes: 126
Hi @Numlock,
Just to confirm is this a Plusnet branded Sagecom router?
 Alex H
Numlock
Hi - yes it is the Plusnet branded Sagecom router
TheMightyAJ
Fixes: 126
Thanks for clarifying this @Numlock. If you'd like to send us the routers serial number and 1st six characters of the MAC code via a private message then we'd be happy to add this to your account and request a firmware update be patched through.
 Alex H
Numlock
Hi - do you mean the mac address ?
TheMightyAJ
Fixes: 126
Yes please.
 Alex H
