Router thinks I am in Swansea!
nottechy
I have a persistent problem with my last router thinking I am located in South Wales when I am actually located in South East England.
I assume it is something to do with the Plusnet router setting and wonder if there is a fix. Even the speed test app has me in Swansea.
It frustrating getting recommendations for the wrong area.
2 REPLIES 2
sallonoroff
Re: Router thinks I am in Swansea!
Do you mean adverts on websites, etc, think you are in Wales?
I don't think that's anything to do with the router, just the IP address it has been assigned.
See https://www.computerhope.com/issues/ch001043.htm and https://ipaddress.net/
Alex
Fixes: 13
It won't be your router, more likely either a cookie on your device or your external IP.
How are you seeing the complains through Swansea. You've not been using the DVLA recently? (that is a joke before I get told off).
If you go to somewhere like:
www.whatismyip.com
It'll tell you your external IP, just don't post your full one here.
Mine says:
77.99.x.x
When I put that into a site like www.geoip.com I get:
United Kingdom
Sidcup
DA14
Virgin Media
Well United Kingdom and Branson Media are correct, and I know where Sidcup is as it is not that far from me.
