Router reboots daily
RPMozley
Seasoned Pro
Fixes: 18
Re: Router reboots daily
@JRT “If Hub Two is in Bridge mode, can I still see line statistics?”
Currently I don’t think you can view the stats (directly) but they should be visible soon in a firmware update down the road.
@bobpullen may be able to provide a timeframe for the update?
That's RPM to you!!
@JRT
It is possible to get the connection details from the Hub Two.
You need a device with a web browser with a static IP address of say 192.168.1.50 mask 255.255.255.0 connected to a spare LAN port on the Hub NOT the WAN port
http:// 192.168.1.254 will take you to the home page, then Advanced Settings > Technical Log.
Edit: to get the line speed, Event Log and select category WAN
Come back to me if you get stuck
HTH
bobpullen
Fixes: 331
Within a month or two.
JRT
Thanks for the update but I've now gone back to Hub One to try and get the speed back up.  As previously suggested, Hub One syncs significantly faster than Hub Two.  Figures are as follows:
Hub Two:  Down 54.995 Mbps, S/N 6.1 dB.   Up 18.998 Mbps, S/N 6.2 dB.
Hub One:  Down 54.995 Mbps, S/N 7.8 dB.    Up 18.995 Mbps, S/N 6.1 dB.
Previously with Hub One (05/10/22) :   Down 61.93 Mbps, S/N 6.0. Up 20.00 Mbps S/N 6.6 dB
From the above, I guess the system has “throttled” the line and it won’t go back up with a re-boot.  Also, the download speed on the BT speed tester is just on the minimum speed which would allow a fault report to proceed?
Hopefully this isn’t as good as it gets?  Any help would be much appreciated.
