Router password incorrect
FIXED- Subscribe to RSS Feed
- My Router
- Router password incorrect
22-11-2017 11:55 PM
I am having trouble logging in to my router settings. Each time I go to 192.168.1.254 and enter the password on the reference card and the back of my router, it has an error message saying it is incorrect.
Is there any way to change the password for the router or find out what it is?
Any help would be appreciated.
M
Fixed! Go to the fix.
Re: Router password incorrect
23-11-2017 8:38 AM
Two thoughts:
1) The password is case-sensitive (have to mention that!)
2) Is it possible the password has been changed (very unlikely if you haven't done it and have owned it from new.)
A factory reset of the router will reset the password to the default if necessary
23-11-2017 8:53 AM - edited 23-11-2017 9:02 AM
I am entering the password correctly and it has not been changed since I received it.
I have tried a factory reset, but this has not resolved the problem.
Is it worth contacting plusnet to get a new router or is there a way to find out what the password it?
M
23-11-2017 9:20 AM
Can you try a different device and/or browser?
I am sometimes inexplicably unable to log in via a wireless tablet, but have never failed to using a wired PC.
(Can't comment on whether PlusNet would replace a router which was otherwise apparently functioning OK.)
23-11-2017 10:42 AM
It is probably a long shot but there are instances when it matters whether you use the numeric keys along the top of the keyboard or the 'calculator' number keys on the right hand side. It might just be worth trying both.
23-11-2017 11:01 AM
Depending on the font, there can be confusion between, for example an upper case 'B' and a figure '8'. Or an upper case 'S' and a figure '5'.
ADSL2+ Billion 8800NL
23-11-2017 11:56 AM
If you have a Hub Zero (2704n) and using Safari, try a different web browser as suggested by JayG.
23-11-2017 12:01 PM
Post what device you're trying to use to login, PC/Mac/Tablet/Phone etc, and the model. It may help us to understand why it isn't working.
23-11-2017 1:21 PM
Thanks for the advice.
