Router only covers a tiny bit of the house?
FIXED- Subscribe to RSS Feed
- My Router
- Router only covers a tiny bit of the house?
- « Previous
- 1
- 2
- Next »
Re: Router only covers a tiny bit of the house?
04-08-2020 3:44 PM
Thanks for your help @Bogbody as you might have guessed, I've got no idea what I'm doing when it comes to wi-fi, broadband etc!
Since I moved in and installed the Plusnet router I had intermittent problems with the 2.4GHz. Some days fine and some days every 5 minutes everything would be extremely slow or I couldn't access the internet at all. This would happen even if I was in the same room as the router. After a while it would be back to normal.
When I told Plusnet they just suggested I use 5GHz instead which has been stable with no dropping out. But it looks like it's going to be more difficult to extend the signal for that band.... 😞
I've checked channels and it looks like next door one way is using 1 and other way is using 6 so I've changed to 11 but that hasn't helped the signal strength.
04-08-2020 7:25 PM
Difficult one @katesam
See how many Wi-Fi networks are around where you live, it is possible one is interfering with yours.
04-08-2020 7:45 PM
Thanks @Alex
Only 1 other network shows up in wifi settings for phone, laptop etc. I scanned on WifiInfoView and that shows 3 more networks (all Virgin Media). How can I tell if one of them is interfering with mine? This afternoon I switched my 2.4GHz band from channel 1 (which next door is using) to channel 11 (which only 1 other network is using) and tried that out again instead of the 5GHz band. But I've already had a couple of issues of very slow connection and one brief loss of connection - same as before.
04-08-2020 9:26 PM - edited 04-08-2020 9:31 PM
You have to remember that the other person may not be aware of a problem. However, there are idiots that deliberatly use kit to jam wifi. !!!!
Some of the wifi apps will suggest a channel to use. If you have intermittent interference try to check the coverage when its not working properly. You may have a neighbour using a bit of kit (like a hotspot router or wifi printer) that causes interference only when its in use???
Sounds to me like you would be better investing in 5GHz kit????
04-08-2020 11:08 PM
None of my Wi-fi stuff supports 5GHz "kit", including my mobile and a couple of laptops. Changing my "kit" would be slightly pricey - and not guaranteed to work, anyway.
My router has its 5GHz feature disabled by me.😀
12-08-2020 8:42 AM
@Bogbody thanks for the TP Link suggestion. Just got a dual band ac wifi kit and with the extender upstairs I now get decent wifi up there (not just in the room above my router!). The back of the house downstairs still needs a boost so I'll get another one for back there and hopefully will have normal wifi throughout the house
- « Previous
- 1
- 2
- Next »
- My Router
