Router is creaking and has cobwebs in its firmware
FIXED- Subscribe to RSS Feed
- My Router
- Router is creaking and has cobwebs in its firmware
21-04-2020 6:43 PM
I have resorted to the power button today on the router, it decided massive packet loss was a good thing and would not serve the web management page so it had an enforced rest.
This has happened a couple of time since but it has managed to recover.
The firmware looks to be a bit old
3 - Firmware version: | 7.273.1_F2704N_Plusnet |
4 - Board version: | F@ST2704N |
5 - Mode | Fibre |
I believe you need to push the firmware for updates to this device ?
Can somebody wind a handle somewhere to make this happen please
Fixed! Go to the fix.
Re: Router is creaking and has cobwebs in its firmware
22-04-2020 10:22 PM
Hey if you are all a bit busy to push a firmware update, that's OK, these are unprecedented times after all.
I might just buy another bit of hardware to replace both the boxes and lob this kit in the bin.
When I say bin I mean the W.E.E. skip when I can go there again.
I'll make sure the new kit also works with Zen, just in case that becomes plan B.
23-04-2020 4:23 PM
Not sure if it's likely to help with your problem, but I've just pushed a more recent firmware to your device. It will have rebooted to apply the update.
23-04-2020 5:57 PM
Many Thanks Bob!
It was lagging like Quake on Dial-up at points, lets see how it goes with less cobwebs.
24-04-2020 5:10 PM
Just to follow up, this seems have made a huge improvement to throughput and stability!
It could just be people have been slacking off as its Friday but I am happy with this upgrade.
Thanks again Bob.
Somebody at Plusnet buy that man a beer.
02-05-2020 2:50 PM
Hi @bobpullen
Any chance you can push the latest firmware to my router, with the 5Ghz fixes.
I'm a returning customer (activated on 30th) and have had to resort to dusting off my old Hub 1 as new router was only dispatched after a call to support and is still in the post.
Current firmware is Software version 4.7.5.1.83.8.237.2.2 | Last updated 27/10/17
02-05-2020 3:45 PM
Hi @bobpullen .
Could you do the same for me please?
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 28/03/19
04-05-2020 5:27 PM
@tonycathome & @rjweath, this thread is about the Plusnet Hub Zero, not the Plusnet Hub One.
Regardless, I've pushed an update to your router @tonycathome - you'll need to reboot to apply it.
@rjweath, I've replied to the message you sent me.
For anyone else who may be looking for Hub One updates, please refer to the thread here.
05-05-2020 8:26 PM
- My Router
