Router firmware update
stubie
My router currently has the following firmware :
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ73108406
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated Unknown
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 16:50:24
6. Data rate: 1973 / 18060
7. Maximum data rate: 2121 / 17469
8. Noise margin: 6.5 / 6.9
9. Line attenuation: 44.2 / 31.2
10. Signal attenuation: 33.6 / 25.5
I am getting frequent issues with dropouts and it seems the only way to resolve the issue is to reboot the router.  Would it be possible to push the latest firmware to my router so that it at least has the latest firmware on it.  The current level has never been updated since I have had the router, and seems to be quite backlevel compared to what I see more recent firmware levels to be.
5 REPLIES 5
MatthewWheeler
Fixes: 436
Re: Router firmware update
Apologies for the delayed response.
Your router is using the latest firmware.
If you're still having issues please raise a fault here.
 Matthew Wheeler
SteveA
Isn't 4.7.5.1.83.8.237.2.2   the latest version (that's what got pushed to my Hub One over night).
SteveA
If you go to Troubleshooting  - Event Log and select TR069 from the drop down do you get entries like:
12:57:38, 16 Apr. (19446.950000) CWMP: session completed successfully
12:57:38, 16 Apr. (19446.780000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
12:57:36, 16 Apr. (19444.710000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
12:57:36, 16 Apr. (19444.700000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
12:57:35, 16 Apr. (19444.310000) CWMP: Initializing transaction for event code 2 PERIODIC
07:35:52, 16 Apr. ( 140.960000) CWMP: session completed successfully
07:35:52, 16 Apr. ( 140.770000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
07:35:41, 16 Apr. ( 129.750000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
07:35:41, 16 Apr. ( 129.750000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
Or do you see something about unable to connect? If so then its likely that your router is on the ceased list (Mine got on it for no apparent reason).
stubie
According to other comments, the level of firmware isn't the latest. How do I get the latest version?
stubie
I'm getting entries as below:
20:24:11, 16 Apr. ( 141.420000) CWMP: session closed before all requests were acked
20:24:11, 16 Apr. ( 140.870000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
20:24:07, 16 Apr. ( 137.440000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
20:24:07, 16 Apr. ( 137.440000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,6 CONNECTION REQUEST,4 VALUE CHANGE'
20:23:37, 16 Apr. ( 107.160000) CWMP: session closed before all requests were acked
20:23:37, 16 Apr. ( 106.950000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
20:23:37, 16 Apr. ( 106.900000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
19:23:10, 16 Apr. ( 92.280000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
19:23:10, 16 Apr. ( 92.270000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,1 BOOT,4 VALUE CHANGE'
19:22:57, 16 Apr. ( 79.580000) CWMP: session closed due to error: Could not resolve host
19:22:55, 16 Apr. ( 77.300000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
19:22:55, 16 Apr. ( 77.280000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,1 BOOT,4 VALUE CHANGE'
19:22:23, 16 Apr. ( 45.570000) CWMP: session closed due to error: Could not resolve host
19:22:17, 16 Apr. ( 38.750000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
19:22:17, 16 Apr. ( 38.740000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,1 BOOT,4 VALUE CHANGE'
19:22:16, 16 Apr. ( 38.450000) CWMP: Initializing transaction for event code 1 BOOT
19:22:16, 16 Apr. ( 38.450000) CWMP: Initializing transaction for event code M Download
16:27:29, 16 Apr. (216220.200000) CWMP: Initializing transaction for event code 2 PERIODIC
12:11:23, 16 Apr. (200854.430000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
12:11:22, 16 Apr. (200853.200000) CWMP: session closed before all requests were acked
12:11:22, 16 Apr. (200853.010000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
12:11:19, 16 Apr. (200850.580000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
12:11:19, 16 Apr. (200850.570000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,6 CONNECTION REQUEST,2 PERIODIC,4 VALUE CHANGE'
There do seem to be errors in there about session closed....  Does this indicate there is a problem?
