Router alternatives
paul1974
Router alternatives
Does anyone know of any third party routers which are more configurable than the default Plusnet router which will be compatible?
7 REPLIES 7
Fixes: 382
Re: Router alternatives
@paul1974 You kind of take your pick, there are any number of third-party routers out there, and PN allow you to use any of them. Are you on FTTP or FTTC?
Fixes: 117
@paul1974
PN have always been happy for customers to use their own equipment and provide the settings required in their Help pages.
If you're on FTTC you should get one that also works with FTTP if it comes your way.
Work out what you want from the router and then go looking.
paul1974
Thanks for the messages. My connection is meant to be upgraded next year so it'll need to support both.
I'd like a router which I allows me to have a lot of control over dhcp and DNS. Ideally I can create my own local DNS zones and fix ethernet addresses to IPs. Support for DNS over https would be a requirement too. If you have any recommendations that would be great.
Fixes: 147
If you currently have a Hub two then you can configure it to be a modem (bridge mode), then you could then look for a router only device which supports a WAN PPPoE connection.
Can't help with the DNS over https but most  3rd party routers would have the basics you are looking for.
DJMcKenzie87
Hi Good Evening I've recommend this Router AX5700 Dual Band WiFi 6 Gaming Router, PS5 compatible, Mobile Game Mode, Lifetime Free Internet Security, Mesh WiFi support, 2.5G Port*, Gaming Port, Adaptive QoS, Port Forwarding
New-generation WiFi 6 - Enjoy ultrafast speeds up to 5700 Mbps with the latest WiFi 6 (802.11ax) and 160MHz channels
Mobile Game Mode - Minimize lag and latency for mobile gaming with just a tap on the ASUS Router app
True 2 Gbps wired and wireless speeds - Aggregated 2 Gbps WAN connections, wired 2.5 Gbps port* and WiFi 6
ASUS AiMesh support – Create a flexible, seamless whole-home mesh network with AiMesh-compatible routers
Commercial-grade home network security – Lifetime free ASUS AiProtection Pro, powered by Trend Micro™, with WPA3 and advanced Parental Controls to protect your home
https://www.asus.com/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax86u/
Ive got this Router anyway it's work amazing
As of April 24th2026, I am now utilizing Sky Broadband, which offers full support for IPv6 addressing. Broadband Status page https://stats.uptimerobot.com/i06TwWNbhx
https://gaytxtbudzuk.co.uk/ my website
paul1974
Thanks for the replies. To start with I think using a WiFi router connected to the Plusnet hub is a good start.
paul1974
Thanks for the advice. I bought a GL.iNet GL-AXT1800 to plug directly into my Plusnet router. It comes with OpenWrt which made things a lot easier. I'm really impressed with it.
