Router Upgrade
lockeman
Router Upgrade
I currently have a Plusnet One Router but today I have received a Plusnet two Router and I would like to know if it is possible to backup router from the One device and restore this to the Two device.
I have various wireless & firewall setting that took a while to get to work correctly so I was hoping this backup & restore would work?
Thank for you help.
3 REPLIES 3
Fixes: 585
Re: Router Upgrade
@lockeman I'm afraid it won't. They're completely different devices. Best thing is to take some screenshots of the settings on the Hub one. If you change the Hub two wireless SSID and password to be the same as the Hub one, that should go a long way to help with the changeover. Bear in mind, though, that the 2.4ghz & 5ghz bands can't be split on the Hub two.
lockeman
Re: Router Upgrade
Thanks for the advice, I thought that would be the case but I am pleased confirmed the situation.
Fixes: 1,495
Re: Router Upgrade
Moderators Note
This topic has been moved from Fibre to My Router
