BT Hime Hub 6 - Turn off BT WiFi??
BlueEagle365
I am using a BT Home Hub 6 on my Plusnet FTTC connection. Is there any way I can disable the BT Wifi network that the router has? I know it's part of the BT broadband service but assume it is not actually being used on my Plusnet connection (I am aware BT owns PN so so might still work for BT customers).
1 REPLY 1
Fixes: 480
Re: BT Hime Hub 6 - Turn off BT WiFi??
@BlueEagle365
You can disable it on the Business versions but not on the residential ones. Over the many years now that Plusnet customers have used these hubs there have been no reports of there ever been any traffic on this SSID.
