Router Recommendations for Full Fibre 900 (wireless not needed)
raoulsilva
I am going to be signing up with PN Full Fibre 900 service in the near future and want to start getting the kit I need ready for when it's installed.
What is the most reliable router for this service? I don't want anything with wi-fi on - just the routing bit.
Thanks for reading.
8 REPLIES 8
markhawkin
Champion
Fixes: 22
Re: Router Recommendations for Full Fibre 900 (wireless not needed)
Try a Draytek 2927 (there is a non-wifi version) or perhaps a Ubiquiti UniFi UCG-Ultra Cloud Gateway Ultra Broadband Router.
Both will require some "learning" but should run trouble free for months or years.
To get the full 900Mb/s on the Draytek you will probably need to turn "hardware acceleration" on.
raoulsilva
thanks for that Mark, will check them out 👍
Fixes: 251
Equally you will need kit which can perform at that level ... which unless one is doing something very specialised is likely to be over kill.  Frankly in a residential setting, I do not understand the thirst for commercial grade infrastructures.  I recall the days when data centre links running at sub Gbit were over kill.
markhawkin
Champion
Fixes: 22
There is a bit of a paradox here.
The ISP supplied routers (Plusnet's Hub 2 etc.) can do the throughput (I assume using hardware acceleration) but are not "feature rich".
It isn't the speed of my 145Mb/s Plusnet service which needs a Draytek, it is other functionality (for example an isolated network for things like the doorbell and other IoT things I don't trust) that makes a Draytek or similar desirable.
Fixes: 118
@raoulsilva
Given that WiFi is not required I see no problem with the PN Hub2 unless you want a Router with bells and whistles on it.
While you can do research I would suggest not doing anything until Full Fibre is installed and running and then see what may be required.
Fixes: 251
There is also the consideration of what kit one has presently and why it’s thought might not be suitable for the new service.  There’s an implied presumption of a bottleneck … but no context of what the user needs to support.  Throughput of what, network segregation how many devices doing what?
raoulsilva
Thanks to everyone for posting.
I am sure the equipment Plusnet send out is up to the job (any idea who makes their kit?), otherwise they wouldn't use it.
I am not sure if they do the same as Virgin Media where their equipment is locked to their own DNS? I would rather use Cloudflare or Quad9.
I have Unifi access points around the house hence no need for wireless.
I am going to use OPNsense so will probably just keep the Plusnet router with as many functions turned off.
markhawkin
Champion
Fixes: 22
As you are in the Ubiquiti ecosystem their Cloud Gateway Ultra would be the obvious choice if you wanted to replace the Plusnet Hub. It's reasonably priced as well.
