Requesting new hub 2 router
Morphears
My router, hub one is getting really hot, I have had it many years now, am I able to request a hub 2 to replace it?
10 REPLIES 10
Fixes: 387
Re: Requesting new hub 2 router
@Morphears So far as I know, you can - at the moment - only get a Hub2 on re-contract. How long have you got left? A replacement would still be a Hub1.
northender
You can buy a BT Smart Hub 2 from a well known online auction website from around £20 (used) & around £30 (new), and use it with Plusnet.
Configure it as here:-
https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/td-p/1795292
That's the way I access Plusnet currently.
Morphears
Thanks northender, very helpful! I will have a look 👍
northender
Do you use FTTC, if so, there's a new one at £22 +£5 p&p at the moment.
it's basically the same type as the newly launched Plusnet Hub 2.
Make sure it's got the new circular BT logo.
P.S. No, it's not me selling it !!
Morphears
Hi ya, yes fttc...until they start doing fttp, though I am only a few doors down from the exchange so get top speeds...so might stick with what I have...
Thanks for the advice, much appreciated!
Strat
Fixes: 565
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
Fixes: 480
For two years now BT have been charging customers who do not return their Smarthubs unless they return them. So whilst  you will see adverts for 'new' ones, the chances are that they are at best unused and still in their original packing.
In my experience these hubs are reliable. Also BT are still providing firmware updates, so there's no real advantage in paying for allegedly new ones.
The Plusnet Hub 2 is closer to the FTTP version of the BT Smarthub than the FTTC model in that they have 3 LAN ports and 1 WAN as opposed to 4 LAN ports.
For my money I think that the best alternative to a Plusnet Hub 2 is either the FTTP or FTTC model of a Business version of the original Smarthub. Both versions work on FTTC.
Fixes: 118
Don't be confused (as I was) by model names.
The PlusNet HubOne is basically a BT HH5. Then BT brought out the HH6 which is sometimes referred to as the SmartHub1.
BT's current version is the SmartHub2 on which the PlusNet HubTwo is based.
Morphears
Yeah I read somewhere that Plusnet, being part of BT get the old BT models as their new ones, when they update....all very confusing...
Thanks for the info 😊
LifeonMars
Seasoned Pro
Fixes: 12
The BT Smart Hub 2  is similar to the New Plusnet Home Hub 2 .   The  Plusnet Home Hub One is similar to the BT Home Hub 5.
