Port forwarding rule: microsoft multiplaye alexedispc26 3074:3074 UDP
- My Router
- Re: Port forwarding rule: microsoft multiplaye ale...
a week ago
I have a Hub Two,
In my Port forwarding rule I have:
Rule Name:
Device:
alexedispc26
(IP: 192.168.1.218)
Internal/External ports Start/End:
3074:3074
3074:3074
Protocol:
UDP
I have probed the IP with Zenmap, but nothing is returned, where has this come from, no one in the property has manually entered this rule.
Any thoughts appreciated.
Re: Port forwarding rule: microsoft multiplaye alexedispc26 3074:3074 UDP
a week ago
@1R27cD5n welcome to the forum.
I would expect the rule has been added by UPnP, there would be tick under UPnP for the line where that rule is in port forwarding.
I would expect and entry in the technical event log showing rule been added..
Monday - last edited Monday
Thanks, yes there is a tick against the UPnP.
Ok, I understand the Log is kept in RAM, despite their being 250 pages of it, I restarted the router just a few weeks ago, so it may not have the line/s that added this Port Rule.
Be worth a look anyway, it maybe occurring at startup.
To search the log I must export it, upon trying to open the exported csv in Libre Calc, the import window does this (see below) - with what appears the delimiter being some form of odd bracket type character, so upon importing Libre Calc complains their are too many characters for the opening cell, any thoughts ???:
NOTE I have tried to paste a screen shot of the import window - but trying to Post here brings a system complaint that my post is over 50,000 characters, I then went to attach it but realised that might be a bad idea.
The import window showed the contents of the CSV to contain chinese characters !, I am very curious to see what does get imported if this can be solved.
The event log should survive a Hub reboot.
On linux system you should be able to use a "text editor" to view the event.log
Below the reply window there is a paper clip, use that to attach the event.log to a reply
Edit: you can disable UPnP on the Hub, the setting if I recall is found in Firewall.
Monday
Yes, Ubuntu's default text editor opened the CSV file fine, no chinese characters ! and yes it looks like its survived from the start of the year.
Searching the log, I cannot find 'Multiplaye' or 'microsoft', but 'AlexEdisPC26' brings up these examples (xx's replace MAC address):
19:28:18, 13 Nov. 2.4G Client associate from xx.xx.xx.xx.xx.xx (IP=192.168.1.218) RSSI=-74, Rate=117Mbps, host AlexEdisPC26
19:28:18, 13 Nov. DHCP lease issued 192.168.1.218 to xx.xx.xx.xx.xx.xx AlexEdisPC26, lease duration is 86400 seconds
19:34:00, 13 Nov. 5G Client associate from xx.xx.xx.xx.xx.xx (IP=192.168.1.218) RSSI=-77, Rate=468Mbps, host AlexEdisPC26
I could attach the whole log, but would that be wise ?
Monday
@1R27cD5n There is nothing in that log which is 'unwise' to post.
Monday
If you search for FWL in the event log do you see any port forward messages
Each category on the event log has a maximum line number for entries, it could be the UPnP rule port forward creation have been lost due to other Firewall reported activity
Wednesday
Thanks for your replies.
My Log contains Mac addresses, are these not unique identifiers.
I have searched the log for FWL and nothing was found.
As an aside, I have run Nmap on my network, and found IP 192.168.1.179 port 111 open, is this my Hub ?
Wednesday
Wednesday
Unless you've changed it the Hub two IP Address is 192.168.1.254.
As to 192.168.1.174 port 111 if you look at >Home >My devices you should see a list of allocated IP addresses for each device on your network, hopefully with a hostname. Do you have a NAS drive?
Wednesday - last edited Wednesday
Sorry I left out the answer to
MAC Address identifies a device at the network card (NIC) level, so they are unique but, the MAC Address is the not the complete story.
The MAC Address does refer to a manufacture of the NIC, but this does not necessarily match the maker of the device (PC, NAS server, etc)
Example; I have a HP laptop with an Intel Manufactured NIC
- My Router
