Port forwarding a PS4 with Plusnet Hub Two
Gringo1
Hi, I'm experiencing slow gameplay on FIFA 23, and have done for years. I want to try port forwarding my PS4 with Plusnet Hub Two hub to see if that helps. I've searched the internet but am struggling to find any step by step guides on how to do this. I know the PS4 IP address and can get onto the Hub Manager page ok. I'm using the port 1 Ethernet connection and can find the create a new port forwarding rule. From that point on i get very confused on what information to enter, i.e rule name, External ports start and end, Internal ports start and end, and protocol. Any help would be very much appreciated, or any other suggestions on what could improve gameplay. Thanks
Tags (1)
5 REPLIES 5
Re: Port forwarding a PS4 with Plusnet Hub Two
Hi @Gringo1 welcome to the forum.
My my research you need these rules, is this the same as you have found?
To add a port forward rule, from the Firewall section of the Hub Two click on "Create a new port forwarding rule"
The name needs to be unique, I would suggest PS4-FIFA23, I have created a few examples of what's require, hope it makes sense?
Use the device name rather than the IP Address.
Add the necessary data into the fields and click on + to create the new rule.
Rule with a range of ports
Click on + to add the rule each time you add more port/s  When you've finished click on save.
I've only created a couple of examples.
HTH
Dan.
Fixes: 480
Moderators Note
This topic has been moved from Broadband to My Router
Fixes: 1,495
This is what I'm using for my PS5, should be the same as it's for PSN.
Gringo1
Hi Dan, thank you so much for this. I've played a few games now and things definitely seemed to have improved. I really appreciate your help.
Gringo1
Thank you so much for this, I'm sure gameplay is now improved. Much appreciated.
