Port Forwarding Hub One
Peter_Pi
I want to forward a few specific ports to one internal IP address.
Its not anything in the dropdown list. I've done the Advanced setting, Firewall, Port Forwarding, Manage Games And Applications, Add User Defined Game Or Application, Copy an existing game/application "No" button. But I can only translate the ports, not forward them to a specific IP. Am I wasting my time? If so, I'll buy another router that'll do the job.
I have plusnet at another location and use a TP-Link Archer 400 which is easy to setup and it does a great job. This one is at another location and will become live tomorrow, so I'd like to sort it over the weekend, if possible.
Cheers
Pete
3 REPLIES 3
bobpullen
Fixes: 290
Re: Port Forwarding Hub One
Once the game/app and associated ports are defined, you should be able to assign it to an IPnetwork device on the previous screen (the newly defined game/app should appear in the list).
Peter_Pi
OK, thanks for the swift reply Bob. I've disconnected it at the moment, but I'll give it another go tomorrow, after the new service has been activated.
I'll keep you posted.
Pete
Peter_Pi
Just tried it, connected the VOIP device, and it now show the ports are open.
From now on, its up to me to finish the job.
Cheers
Pete
