Port 53 restarts the Router randomly
- My Router
- Port 53 restarts the Router randomly
24-08-2018 6:30 PM
Hi All,
I have Virtualmin (webserver) that I do development testing work on and have noticed that each time I create a Webspace the router restarts (WiFi Drops then router seems to restart - or at least lose internet connectivity for a brief time) - Running tests I have discovered that it appears that port 53 is the culprit, which of course cannot be removed as its the DNS for the nameservers connecting the domain to the Virtualmin server. My question is, has anyone else had this issue before and if so what did you do to fix it? I have contacted Plusnet and they sent another router out to me, but same thing is happening. I am not sure if its the Plusnet Hub One router causing the issue or some other underlying issues with my connection.
Any help/advice would be most appreciated.
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 04/04/18
Re: Port 53 restarts the Router randomly
24-08-2018 8:35 PM
Moved to 'My Router' from 'Fibre' as it seems to be a hardware issue.
24-08-2018 9:03 PM
25-08-2018 2:40 AM
So I have created a separate port forwarding rule that virtualmin requires with all the relevant ports open. When I discovered that the router resets I started one by one taking out the ports from the rule and adding them again. IE removing all rules adding them one at a time until I found the one that caused the issue. Once I found that port 53 (all flavours of it) was causing the issue, I removed it and created it in a separate rule. Disabling the main rule virtualmin rule and trying again. It seems that something either the router or the plusnet DNS ips (that annoyingly can't be changed) are somehow blocking the connection and thus forcing the router to restart. I'm not sure if plusnet DNS is thinking that my router is getting DDoS'd and forcing a restart but it's very strange nonetheless. I hope that clears things up a bit.
27-08-2018 11:50 AM
30-08-2018 7:44 PM
31-08-2018 5:38 PM
31-08-2018 5:46 PM
01-09-2018 3:28 PM
Hi Bob,
I have now PM'd you 2 messages, one has the information to set up virtualmin the other is a video to show you what happens when it creates a new domain. - Let me know if you haven't received them.
- My Router
