Plusnet router keeps resetting
Nealonb
This has been going on for a few months now but it's frequency has gotten to the point where I can't carry on as usual anymore.
Everyday, seemingly at random, my PlusNet router resets. The broadband will drop out, the light will go from blue to green. It will then turn blue again. The light then turns orange/orange flashing (something that happens every time I reset it manually), it then finally turns blue again and the WiFi continues as usual. The whole process takes roughly 3-5 minutes.
I'm really not sure what's causing this and the other forum posts I've found on the issue haven't been much help.
6 REPLIES 6
Fixes: 585
Re: Plusnet router keeps resetting
Is it a Hub 1 ?
Does the event log contain messages like ' watchdog reset ....' ?
Nealonb
Yes its a Hub 1, I should have specified that!
Some of them do have "watchdog reset" yes
18:30:32, 01 Jan.( 35.230000) 2.4 GHz Wireless: Rescan, Reason: 'Power-​up'
18:30:32, 01 Jan.( 35.230000) Wire Lan Port 3 up
18:30:32, 01 Jan.( 35.230000) Wire Lan Port 1 up
18:30:32, 01 Jan.( 34.830000) WAN Auto-​sensing running.
18:30:28, 01 Jan.( 30.900000) System up, firmware version: 4.7.5.1.83.8.289.1.3
18:30:25, 01 Jan.( 28.400000) WPA2 mode selected
18:30:25, 01 Jan.( 28.400000) WPS enabled
18:30:23, 01 Jan.( 26.420000) WPA2 mode selected
18:30:23, 01 Jan.( 26.420000) WPS enabled
18:30:14, 01 Jan.( 17.550000) System start
18:30:14, 01 Jan.( 17.550000) Boot reason: watchdog reset (cause: 0x3)
and earlier today
17:13:22, 01 Jan.( 41.560000) 2.4 GHz Wireless: Rescan, Reason: 'Power-​up'
17:13:22, 01 Jan.( 41.560000) Wire Lan Port 3 up
17:13:22, 01 Jan.( 41.110000) WAN Auto-​sensing running.
17:13:18, 01 Jan.( 37.200000) System up, firmware version: 4.7.5.1.83.8.289.1.3
17:13:14, 01 Jan.( 33.620000) WPA2 mode selected
17:13:14, 01 Jan.( 33.620000) WPS enabled
17:13:11, 01 Jan.( 30.670000) WPA2 mode selected
17:13:11, 01 Jan.( 30.670000) WPS enabled
17:12:58, 01 Jan.( 17.580000) System start
17:12:58, 01 Jan.( 17.570000) Boot reason: watchdog reset (cause: 0x3)
Nealonb
Yes its a Hub 1 (should have specified apologies).
And yes I am getting that message a few of the times its happening.
Nealonb
Yes its a Hub 1 and yes I am seeing that message pop up!
18:30:32, 01 Jan. ( 35.230000) 2.4 GHz Wireless: Rescan, Reason: 'Power-​up'
18:30:32, 01 Jan. ( 35.230000) Wire Lan Port 3 up
18:30:32, 01 Jan. ( 35.230000) Wire Lan Port 1 up
18:30:32, 01 Jan. ( 34.830000) WAN Auto-​sensing running.
18:30:28, 01 Jan. ( 30.900000) System up, firmware version: 4.7.5.1.83.8.289.1.3
18:30:25, 01 Jan. ( 28.400000) WPA2 mode selected
18:30:25, 01 Jan. ( 28.400000) WPS enabled
18:30:23, 01 Jan. ( 26.420000) WPA2 mode selected
18:30:23, 01 Jan. ( 26.420000) WPS enabled
18:30:14, 01 Jan. ( 17.550000) System start
18:30:14, 01 Jan. ( 17.550000) Boot reason: watchdog reset (cause: 0x3)
Fixes: 585
Your Hub is faulty. You can either call customer services and request a replacement or wait for one of the Plusnet help team staff to spot this thread and arrange it
Fixes: 1,495
Moderators Note
This topic has been moved from  Broadband to My Router
