Plusnet hub2 and domains
dws1900
Hi
My network foo.ba uses foo.ba as its internal domain.
The domain name, foo.ba is used within various servers where using no domain, ie fred will not suffice,
it must be for example http://fred.foo.ba , http://fred will not work.
I want to use my Plusnet Hub2, and I cannot set the domain name, foo.ba any where, which means some servers cannot be accessed.
Is there a solution to this, without using an extra dhcp / dns service?
1 REPLY 1
markhawkin
Champion
Fixes: 22
Re: Plusnet hub2 and domains
"Is there a solution to this, without using an extra dhcp / dns service?"
I don't think so.
It sounds like you want something like a Raspberry Pi set up as a DHCP/DNS service (and turn the service off on the Plusnet Hub2.
