Plusnet One Hub into Bridge Mode (attempting to set up AMPLIFI wifi mesh)
dmd2020
Hoping someone can offer some advice on how to put my Plusnet One Hub into Bridge mode so that I can set up an Amplifi Wifi Mesh system. They're not currently connecting to each other and I'm stuck! I've looked in the Hub settings to see if I can set up manually but truthfully I don't have a clue.
Could anyone offer any advice? Thanks so much!
4 REPLIES 4
Shep41
Seasoned Pro
Fixes: 7
Re: Plusnet One Hub into Bridge Mode (attempting to set up AMPLIFI wifi mesh)
I don't think the Hub one can be put into bridge mode. But I'm sure someone will correct me if I'm wrong
Fixes: 585
@dmd2020  @Shep41 is correct, the hub one does not support bridge mode.
You will need to use the mesh system in access point mode if it supports it.
bill888
Champion
Fixes: 40
fwiw, list of bridge modem options
https://community.plus.net/t5/My-Router/What-is-a-suitable-VDSL-modem-for-ASUS-RT-AC86U/m-p/1737761#...
Fixes: 585
Looks like the Amplify router can be put into access point mode (what they call bridge mode ) , see here https://help.amplifi.com/hc/en-us/articles/220979347-Enabling-Bridge-Mode
