Plusnet Hub Two - Mode 1 (special features?)
tol
Just started using a Hub 2 after my openwrt'd HH5a stopped working.
Where can I find details of the magical features offered in wifi Mode 1?  Everywhere I looked just says Mode1 = more wifi features, Mode 2 = fewer wifi features.
I have several tasmota and espurna (custom firmware) wifi switches and power monitors, some switched to hub2 happily while some, (supposedly the same hardware) can't connect properly.
I will try to switch down to Mode 2 to see if it helps these lost devices,but just wondering what I will "lose" from Mode 1.
Cheers
4 REPLIES 4
Fixes: 585
Re: Plusnet Hub Two - Mode 1 (special features?)
There's a better explanation in this thread https://community.plus.net/t5/My-Router/New-plusnet-hub-two-user-issues-connecting-devices-via-wifi/...
tol
knocked it back to Mode 2 and then Mode 3 but still don't see the devices.  Wondering now if the new ssid is too long or the wpa key too strong.
Still don't know what the "advanced featues" are either, the linked thread gives a little hint at what Mode 3 misses...
Fixes: 480
@tol
My understanding is that the Mode switch controls the wireless standards that are accessible at each level. Mode 1 is all the normal standards up to 802.11ac whilst the other two bands limit the hub to the earlier and basic standards.
Some older devices get confused and fail to connect to a hub that caters for the wider available bandwidth when these are available along with the slower older standards with which they are compatible, hence the ability to cut them out.
tol
Thanks, it's the devices anyway and my stronger wifi passphrase.  Mode is not a problem.
I struggled with a new one, the old was deemed not strong by the Hub 2 because which surprised me because it's pretty strong, but it seems Hub 2 doesn't consider any double characters as strong.
New wifi passphrase includes 2 "special" (non-alpha but within ascii range) characters but it seems several of the tasmota switches don't like that (weirdly, several of same type seem fine)
I doubt that the hub 2 (firmware) will allow, but is it possible to set up multiple ssids like I had with openwrt HH5a (hub1)?
