Plusnet Hub 2
banger696
Plusnet Hub 2
Does the Hub 2 have DDNS on the firmware?
4 REPLIES 4
Fixes: 392
Re: Plusnet Hub 2
@banger696 No - it doesn't, but you are quite at liberty to use your own kit.
Fixes: 587
Re: Plusnet Hub 2
@banger696
Depends what you mean by 'have DDNS' ?
It does have a DDNS client which can be configured for some DDNS services.
This thread https://community.plus.net/t5/My-Router/Dynamic-DNS-not-forwarding/td-p/1981781 shows an example using No-IP
I'm afraid I don't use a Hub2 so I don't know what services can be configured
Re: Plusnet Hub 2
@banger696
The DDNS choices are: - DynDNS, NoIP, ChangeIP, EasyDNS, Zoneedit and DNS-O-Matic
banger696
Re: Plusnet Hub 2
Many thanks this answers my question. Smiley
