Plusnet Hub 2 v Hub 1 a personal Review
Chilternphil
Renewed my PlusNet FTTC BB two weeks ago after four years using Hub 1 and upgraded to Hub 2. Having read some other forum threads I thought that some general feedback may be of interest. I had already set up a second hand BT smart hub 2 as a successful experiment last year.
My experience of Hub 2 is that both up and down speeds increased (about 6%) to 65/15 which may be serendipity or just a better S/N performance.  Wi-Fi performance is significantly better (which is a reasonable expectation as it has more aerials and presumably better circuits/software). Before and after the upgrade I measured signal strength/throughput around the house which showed Hub 2 is better but a real example is the TV will now play BBC iPlayer without stuttering whereas previously had to use mains-Ethernet to watch programs.  [That is 2.4 GHz through two external and one internal walls.]  A computer in upstairs bedroom now has a bi-direction link speed of 470 Mbps. Tablets and phones connect with stronger signal and seem to switch seamlessly between 2.4 and 5 GHz bands as one moves about.
In summary, a straight forward upgrade which has significantly improved performance. My one wish would be for a Guest User facility - but hey, I can always buy an expensive personal router if that becomes a problem.
12 REPLIES 12
andy7400
Re: Plusnet Hub 2 v Hub 1 a personal Review
Very helpful, Chilternphil, thank you.
Norrette
Thanks for this, just about to plug in my Hub 2.  I take it that the 5g vs 2.4 clash issue has now gone away?
AJ27
I tried plugging in my Hub 2, upgraded from the original.  Whilst many things connected easily I still had several devices that couldn’t pick up the Wi-Fi even with 5Ghz switched off.  Plus net support said it must be an issue with my devices, despite the only thing having changed being the router.  I have gone back to the original router and everything works fine.  Would love to get the hub 2 working but don’t know how to resolve the issues and plusnet customer service couldn’t help either.
Fixes: 392
Which devices couldn't connect?
AJ27
HP printer, Ring chime (ring doorbell connected ok), smart sockets.
Smart bulb only connected when I turned off 5GHz so I had high hopes that the others would too, but unfortunately not.
Fixes: 392
Try resetting the offending devices to factory default and then retry, while keeping the 5GHz switched off. The printer especially will need this procedure, and I suspect the other items will.
AJ27
Ok thanks. I thought I had done but I’ll give it another try.
bobpullen
Fixes: 331
Another thing you can try is selecting Mode 2 or 3 under the Advanced Wi-Fi settings in the Hub Manager (2 first, and if that doesn't work, try 3).
AJ27
Thank you.  I will give these suggestions a go when I have a few minutes.  👍
AJ27
Hi.  Just got round to trying it again and success! I did a full factory reset on the printer and then the others seemed to connect ok too.  Thanks both for your help.
7up
Fixes: 20
Quick note regarding the firmware..
Hub1 has a list of common applications that can be quickly used to open a port to a selected device. On the Hub2 you have to do it all manually.
The network stuff (listing all connecting devices etc) is a lot superior though.
Greggorio
It has for me. I had to split them with my old plusnet router. So far I haven't needed to
