Plusnet Hub 2 replacement
SimonEv
Hi
I have just had Full Fibre installed (Full Fibre 900) after many years of poor broadband down my phone line !!
I currently have the Plusnet Hub 2 connected and wifi speeds are obviously far faster than I am used to.
During the fibre installation the open-reach engineer did say that I will get faster WIFI speeds around the house if I upgraded the router. Unfortunately, he didn't make any recommendations for an alternative router.
I am not particularly knowledgeable about these sort of things and after looking on amazon I am overwhelmed with the amount of router options and what is suitable.
Can anybody recommend a device that I can simply plug in that can perform better than the Plusnet Hub 2 ?Huh
Many thanks
Simon
4 REPLIES 4
Fixes: 118
Re: Plusnet Hub 2 replacement
@SimonEv
While I can't recommend any routers I understand that you currently wouldn't get more than around 400 down using current WiFi.
To get more you'd need a unit that supports WiFi 6 and devices that support WiFI 6.
Fixes: 118
@SimonEv
Another thing to consider at this time before buying anything is - do you have any WiFi "dead" spots around the house?
This could influence what equipment you buy.
Fixes: 480
Every third party router that you buy have to be configured so there is no plug and play option. However if you advise a preferred device we can hwlp with this aspect.
To be honest, at these speeds you are unlikely to get the full benefit from wireless. If you really need 900Mbps and do not want to spend an arm and a leg getting the best wireless speed practicable then you need to run an Ethernet cable to these high speed devices.
Fixes: 480
Moderator's note:
Thread moved from Full Fibre to My Router
