Plusnet Hub 2 - Log
Correlated
Plusnet Hub 2 - Log
Got my new Plusnet Hub 2 and the event log seems somewhat limited compared to the hub 1,
Certain selections show nothing - for example, If I click 'firewall' filter it just defaults to the 'All' view so I have no idea if my firewall is actually blocking anything or letting everything through or is even on!
Is this how it should be?
Firmware version: v0.05.03.07154-PN
11 REPLIES 11
bobpullen
Fixes: 331
Re: Plusnet Hub 2 - Log
I don't see that here. Whilst certain categories might not be particulalry verbose, I do see entries under the FRWL category Huh
Correlated
Just tried it again and same result.
I just get the 'All' view when the 'FRWL' filter is selected.
bobpullen
Fixes: 331
What browser are you using and do you have any extensions installed? Does the same happen with other categories? Are you able to try a different browser?
Anyone else around with a Hub Two who could help validate?
198kHz
Fixes: 42
I used a Hub 2 for a short while when recently upgrading to FTTC before going back to my Billion.
I did notice that on occasion that it would revert to 'All' when trying to select the firewall category. Re-trying one or two times always fixed it.
FWIW using Firefox with only a PDF viewer extension.
BT technician (Retired)
Correlated
Chrome (latest version) with ublock origin extension.
I have disabled ublock origin extension and same results.
Happens on quite a few of them to be honest.
Just tried it on Edge (which I don't use so has no extensions and is default setting) and same happens.
bobpullen
Fixes: 331
Also using Chrome and uBlock origin.
I am running a slightly newer firmware build. Will see if I can revert and replicate.
In the mean time, I wonder if the browser developer console yields any clues (CTRL, Shift + J, select Network category and try fiddling with the event viewer categories a few times).
I also wonder if it works after a reboot (could be somethign to do with memory consumption).
Correlated
Tried fiddling with the developer console with no results.
Interestingly it works once when I do Ctrl + F5 (hard refresh) but then If I click 'All' again and then back to FRWL same issue arises.
Something to do with the cache then?
Will try a reboot when everyone has gone to bed later.
Correlated
Reboot has not resolved it.
mort7890
Fixes: 4
Hi @bobpullen
Are you indicating that there is an update to thefirmware
Firmware version:v0.05.03.07154-PN
Firmware updated:Unknown
bobpullen
Fixes: 331
@mort7890 - you're on the latest. The build I'm running is not ready for public consumption.
With regards to the problems being reported, I'm yet to try replicating on the v0.05.03... build.
mort7890
Fixes: 4
Hi @bobpullen many thanks for the information and sorry cannot help you with the replication
