Plusnet 'High' Firewall Blocks NTP Sync
Correlated
As the subject suggests I recently increased the firewall to high setting on https://www.plus.net/member-centre/broadband/firewall and since then my router has not been able to sync with NTP.
I continually get these errors:
(138108.060000) NTP synchronization failure!
and the time/date are wrong.
Considering it's Plusnet's firewall that I am using you would have thought it would be able to communicate with it's own servers.
Any help would be appreciated - I don't want to lower the firewall setting.
2 REPLIES 2
Fixes: 480
Re: Plusnet 'High' Firewall Blocks NTP Sync
@Correlated
For information, my firewall is set to high and I have no problems accessing the NTP server.
Have you tried a factory reset on your hub? keep the switch closed for at least 20 seconds or so.
Correlated
Just had my firmware updated and it seems to have resolved the issue Smiley
Software version 4.7.5.1.83.8.289.1.3 | Last updated 28/10/21
