Passwords
Whacko
Passwords
Hi. I have a Sharp smart t. V. I'm trying to connect to hub, I enter password but fails. On hub the password is in upper and lower case, but on tv I can't change from lower to upper case, can it be done??? Help please 😂
1 REPLY 1
Fixes: 585
Re: Passwords
Does this  https://janetpanic.com/how-do-i-get-the-keyboard-on-my-sharp-aquos-tv/  help ?
How do I get capital letters on my Sharp TV remote?
The Remote control does not have caps lock function. If you need to type a capital letter, press and hold the Shift button, and press the letter you need to capitalize.
How do you get capital letters on a Sharp TV?
You can change to the uppercase input mode by pressing the ABC key on the on-screen keypad. Press the upper ABC key or lower abc key again to return to lowercase input mode. Note: If your remote control has Color buttons (YELLOW/BLUE/RED/GREEN), the ABC key function may be assigned to one of those buttons.
