PN router open to ping?
Marksfish
All Star
Fixes: 4
Is the current PN offering open to being pinged? I run a TBB monitor on my connection and that option is a requirement for it to work. I seem to recall that the BT Hub doesn't allow ping, so if I go down the route of changing the router, that would be one to avoid possibly, unless that has changed does anyone know?
2 REPLIES 2
Re: PN router open to ping?
@Marksfish
If you have a Hub two you will find the the ping/icmp setting in Advanced Settings >Firewall >Configuration
HTH
Edit or have a device which responds to ping in the DMZ
Marksfish
All Star
Fixes: 4
I seem to recall the old PN router I had previously responded to ping, but the BT hub I had after didn't, even with something in the DMZ. Good to know if I stay stock I don't need to fiddle too much
Thanks.
