PCI compliance with a 2704N
- My Router
- PCI compliance with a 2704N
Re: PCI compliance with a 2704N
15-03-2019 5:18 PM
@lingtallwill & @Casaitalia2 I've upgraded both of your routers to the latest firmware build.
@Rmontrose your router has dropped off the management platform for some reason, you'll need to factory reset it before I'm able to do the same.
15-03-2019 6:16 PM
Many thanks, firmware is now 7.275.12_F2704N_Plusnet
should this now allow the modem/router to pass the SYN packet tests?
15-03-2019 6:51 PM
If it doesn't, I'd appreciate you messaging me the detail along with the output of any test results and details of who commissioned them.
20-03-2019 9:16 AM
Hi Bob,
The provider is AIB Merchant Service
I've run the scan again and it fails on the same issue:
CVSS Base Score: 5.0 AV:N/AC:L/Au:N/C:N/I:P/A:N
Category: Firewalls
CVE ID: BID : 7487 Other references { cert : 464113 }
THREAT:
It may be possible to bypass firewall rules
IMPACT:
The remote host does not discard TCP SYN packets that have the FIN flag set.
Depending on the kind of firewall you are using, an attacker may use this flaw to bypass its rules.
SOLUTION:
Contact your vendor for a patch.
I'll phone them to see what they suggest.
Andrea
20-03-2019 4:46 PM
Unfortunately we fail with the same issue again -
Worldpay Sysnet.
Category | Firewalls |
CVE | BID : 7487 Other references { cert : 464113 } |
CVSS base score | 5.0 |
Description | TCP/IP SYN+FIN Packet Filtering Weakness |
Threat | - |
Impact | The remote host does not discard TCP SYN packets that have the FIN flag set.<br/><br/>Depending on the kind of firewall you are using, an attacker may use this flaw to bypass its rules. |
Solution | Contact your vendor for a patch. |
PCI compliant | No |
PCI details | - |
Reason | It may be possible to bypass firewall rules. |
PCI details | medium |
Port | 0 / tcp / |
Host name | - |
Host OS | - |
Result
20-03-2019 5:19 PM
Thanks both.
I've raised the issue with the device vendor and will keep you abreast of any developments (ref: PNADSL-16).
I can't provide any assurances as to when I'll have any news though I'm afraid.
20-03-2019 5:23 PM
Are the newer fibre routers backwards compatible to adsl? if so could we swap out?
20-03-2019 7:00 PM
20-03-2019 7:01 PM
Is the scanning solution available publicly? Would be good to be able to replicate the issue. I did try contacting the merchant earlier but their chat functionality didn't seem to be working particularly well.
04-04-2019 12:00 PM
Hi Bob,
I have been asked to provide a screenshot showing that the firmware on the router is up to date with the latest version.
I will try and log in to my router and do this.
Andrea
05-04-2019 12:57 AM
@Casaitalia2, the info at http://192.168.1.254/expert_user.html may be of help.
05-06-2019 9:46 AM
Hi, I'm having the same problem with my PCI compliance. Is it possible to update my router as well
Sagem 2704N
Serial N7162301W000846
Thanks Alan.
05-06-2019 11:30 AM - edited 05-06-2019 11:31 AM
Hi Alan,
I've re-added your router onto the hardware management platform. Could you factory reset it using the pinhole at the back? This should push the latest firmware version down to you within 24-48 hours. Let us know how it goes.
05-06-2019 11:41 AM
Thanks, will let you know.
27-06-2019 7:04 PM
We are having exactly the same problem with PCI compliance for Grindleford Community shop. I am not clear from this forum whether the problem has been solved for the 2704n router. If there is a solution, I would like to know.
