Oldie Router Question
RoyCullen
I hesitate to ask this at the risk of being told there are dozens of similar answers (I did search honestly!).
I've just returned to Plusnet and want to use my Netgear Nighthawk RAX80 router.  I've been supplied with the Netgear Smarthub 2 and the modem block too.
Doing my research, I notice one set of answers indicate using the earlier smarthub model and then putting an ethernet lead between the router to the Nighthawk (can't help but think of Allo, Allo when I use that term!) internet input. However, I was wondering whether that was still the best option (it was a 3 year old answer)?
Should I connect from the modem block directly to the router? If so, is there a guide online to instruct how to do that?
Thanks in advance
4 REPLIES 4
Fixes: 585
Re: Oldie Router Question
@RoyCullen I'm confused, I'd like to try and understand exactly what you've got so that I can suggest the best configuration.
Netgear dont do a SmartHub 2. Do you mean the PlusNet Hub 2 ? and what is the modem block ?
RoyCullen
Hi
yes it is the plusnet hub 2.... its basically the same as the BT Smarthub 2 I had just in white (hence my description).  I also have a couple of Huawei/Bt fibre modems which I got a while ago as I was told to use a third party router. Hope that answers it sufficently
Fixes: 585
Yes, it does.
Set the Hub 2 to bridge mode , it then acts just like a modem.
From the hub homepage, accessed via going to 192.168.1.254 on a browser.
On the home page select the “Advanced settings” box in the bottom right.
Then "Broadband" in the top left.
The scroll down to the very bottom of the page and select the “Bridge mode” check box.
Then connect an ethernet cable from the WAN port on the RAX80 to LAN port 1,2 or 3 ( not the red port 4) on the Hub 2
Configure the RAX80 WAN connection for PPPoE with your PlusNet username and password.
That's it...
RoyCullen
Thank you.... will try this tomorrow as its TV time and I couldn't stand the violence of trying to interrupt wifi in the household on an evening. Greatly appreciated.
