New to fibre settings for TP-Link ac 1200
Markafn
Just about to join plusnet fibre , am possibly going to use the tp link archer ac1200 as my router , I know my user name and password but what other setting do I need to input in the router to get me connected Huh Thanks
43 REPLIES 43
Re: New to fibre settings for TP-Link ac 1200
Just to clarify (because Plusnet have confusing product naming)
When you say "Plusnet fibre"
Do you mean a full fibre FTTP connection ? (i.e. internet to the home via a fibre-optic cable)
or are you referring to the confusingly named "Plusnet Fibre" - which is actually VDSL on a SoGEA connection ?
(where SoGEA is the same as FTTC but without the associated analogue telephone service, via copper wires to the home)
My point being that "Plusnet Fibre" requires a VDSL modem,  which your TP-Link AC1200 appears to not have
RichardB
Seasoned Champion
Fixes: 39
I am not sure that the OP's description of "tp link archer ac1200" is sufficient to identify the router model.
TP Link make several AC1200 WiFi routers, some have a VDSL modem capability.
Markafn
Yes sorry not full  fibre to  house , it’s fibre to the cabinet so VDSL on a SoGEA connection
Markafn
Tp link archer vr400 ac1200wireless vdsl/adsl router
Fixes: 574
Connection settings are here https://www.plus.net/help/broadband/broadband-connection-settings/
Fixes: 472
Moderator's note:
Thread moved from Broadband to My Router
Fixes: 145
@Markafn
The Advanced setting page will look something like
HTH
@Markafn
I see in the TP-Link Archer VR400 User Guide (Chapter 11),  that your router can do QoS.
When you have your Plusnet SoGEA up and running, you might want to test your connection to ensure that is as responsive and low latency as can be achieved with your setup.
The easiest test to run is this - https://www.waveform.com/tools/bufferbloat
If the result shows a "Bufferbloat Grade" of "A+" or "A", then it's all good, otherwise using QoS should achieve those scores.
mort7890
Fixes: 4
Hi @Anonymous just changed over to SoGEA and speeds have dropped so followed your link and tested for bufferbloat result showed an "F" not even fast enough for 4k video. Before goiung to SoGEA my speed was around 40 - 50 Mbps but now shows only 26 Mbps reported to PN so will see what happens next, however I did not try bufferbloat before and unsure of the QoS terminology
Fixes: 374
@mort7890 What router are you using, and has your connection dropped at any point recently? - this sounds like a connection issue, as merely changing to SoGEA should have zero effect on performance.
mort7890
Fixes: 4
Hi @jab1 Using the PN Hub2 Router, dropped at 05.11 this morning reason unknown and have asked PN why. Renewed my contract 2 days ago with PN and the phone was discontinued so presume I am now on SoGEA. Checked the router this morning and my speed has dropped to 28 d/l and 6 u/l
I looked at the default gateway 172.16.17.177 thought I would query it through IP Address Lookup and it appears to be a Private IP Address LAN
Fixes: 374
@mort7890 Any answers from PN yet? If not, and you would like me to cast an eye over things:-
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
mort7890
Fixes: 4
Hi @jab1
No answers as yet from PN also did try to send one screen shot to them but was rejected as it stated it was a virus, my scanner said it was perfectly clear.
Just a small query on the BTW Performance Tester Additional Diagnostics, what do I put in the form please as I do not have a phone number.
Fixes: 374
@mort7890 Don't worry about the additional diagnostics, it is clear from you router details that you have an xDSL connection issue - see the 'uptime'.
Can you please export your Hubs Error log and attach it to a reply.
