New router
twobelowzero
New router
Does anyone know if you can request a new router as an ongoing customer. Mine is now two plus years old and I'm thinking there must be a newer better version available. If not can anyone recommend one to replace the standard issue router. TIA
2 REPLIES 2
Fixes: 387
Re: New router
You can request a new one when you re-contract. As to recommending a third-party one - there are lots out there, it depends how much you want to spend and how many bells and whistles you want on it,
twobelowzero
Re: New router
Thanks - just renewed so I will ask for a new one.
