Need to update Hub One Router
Fixes: 1,662
Re: Need to update Hub One Router
@Clint_1701-A
I've re-added your router's serial number into the hardware component on your account.
If the firmware hasn't updated yet, it should now do within the next 48 hours.
You may need to factory reset the router by pushing a paperclip into the reset pin hole at the back for 20 seconds.
Clint_1701-A
Great thank you, I will keep an eye on it. Nothing yet, but will take another look tomorrow and do what you suggested.
Smiley
bobpullen
Fixes: 330
Again, unecessary. The router was upgraded on it's own accord back on the 5th.
There is also the risk of breaking communication with the management platform by doing this without a subsequent factory reset (although that doesn't seem to have happened in this case).
Fixes: 1,662
@bobpullen
Thanks for the heads up. I was always under the impression that a factory reset is needed to force the router to pull down the latest firmware if it’s stuck on an older version for one reason or another.
And this I did not know. Cheers again for the advice. Smiley
Clint_1701-A
It doesn't look like it's updated to the latest one yet, it still shows the following:
Fixes: 384
AFAIK, @Clint_1701-A , that is the latest release.
Clint_1701-A
Ah okay, thanks for this. Smiley
bobpullen
Fixes: 330
@Clint_1701-A - that *is* the latest firmware.
Edit: Doh! Didn't see the earlier replies.
