Need guest network access
grandad
Morning all.
Currently have Fibre to the cabinet and using the supplied plusnet router.
Not happy to connect household devices which don't have security software to my main wifi so would like to have guest network. Had this previously with old router but lost it when I started using the Hub One.
There was a time when I was sufficiently capable of sorting this myself - but over the last few years I feel that I have been a bit left behind when it comes to broadband/ISPs/routers, etc.
Any help much appreciated.
I am happy - within reason to buy a new modem router - if needed, but I have no idea if there is any kit I could add to current equipment to provide totally secure guest network.
19 REPLIES 19
mort7890
Fixes: 4
Re: Need guest network access
Hi @grandad May be corrected but I think hub one does not support your request, may I suggest you connect a second router as an access point and use that for the guests
Fixes: 118
@grandad
Was your previous service FTTC - if so, you could possibly use your old router. The settings required can be found at
https://www.plus.net/help/broadband/broadband-connection-settings/
grandad
Thanks for the reply.  Correct - the hub one does not offer guest network. I am reluctant to use my old router as I never really got on with it.
grandad
Thanks for the suggestion but as per my above reply I really don’t want to use my old router as I didn’t get on with it (web interface, software, settings etc).
mort7890
Fixes: 4
Hi @grandad Alternatively find a family/neighbour or friend who is/has got an old router and use that as an access point, otherwise no guests.
Fixes: 480
Adding an Access Point with a different SSID will not isolate you from the primary network.
@grandad
Many third party devices come with a guest network. What you need is an ADSL/VDSL combined modem/router with a guest network to replace your hub one. Start with looking at tp-link, Asus and Netgear.
If you find a unit that fits your budget you can always refer back here for an opinion on its suitability.
grandad
Thank you for your helpful reply.
I had a nagging feeling that adding another router wouldn't isolate guests from the main netwrok which is exactly what I'm trying to achieve.
I've previously owned Netgear and TP Link routers although I have to say that I found it easier to set up the Firewall rules on the Netgear.
I've also heard some comments about certain of the BT hubs having a guest network but am having trouble trying to clarify this.
I do need to be careful though in what I buy. I'm used to having the modem combined with the router but so many of today's offerings seem to be router only. is this correct?
Thanks again.
Fixes: 480
@grandad
The Business versions of BT hubs have a ‘Guest’ facility BUT this is for use in pubs, shops etc. It is totally open with no password required so that anyone can get access, not just your guests. I use a Business Smarthub 6 and this feature is turned OFF.
Yes you need to read specifications and get a combined modem/router. With the growth of cable systems and FTTP there are many routers out there as this newer digital technology does not use broadband to get the digital data to your property so do not require a broadband modem.
grandad
@Baldrick1
Thank you again.
Re FTTP and FTTC. there is where I think I have much to learn/catch up on.
In simple terms, is it correct to say that FTTC needs a broadband modem and FTTP does not?
Fixes: 480
@grandad
That is correct. With FTTP  the fibre is terminated at the property with an ONT to which a router is cabled.
Fixes: 118
@grandad
The following link will show the OR ONT (Optical Network Terminator) which is installed. A router is still required but is connected via an Ethernet cable which gives room for manoeuvre. The second link has explanations of ADSL, VDSL and FTTP.
 https://www.ispreview.co.uk/index.php/2019/09/a-look-at-openreachs-compact-fttp-broadband-ont-and-mi...
 https://kitz.co.uk/adsl/fttc.htm
grandad
@Baldrick1
Thank you again for taking the time to reply.
I’m beginning to understand things a little more now and hopefully as/when I replace my router I now know what to look for (VDSL modem).
I don’t think I’ve ever seen an ONT which I’m guessing connects to a router via its WAN port?
grandad
@bmc
Thank you for the reply.
I’ve had a look at the second link.
The first one didn’t work, but no matter - I used it to redirect me to a diagram of a BT ONT
Fixes: 118
@grandad
For some reason the copy and paste of the link went wrong. This should work.
ispreview.co.uk/index.php/2019/09/a-look-at-openreachs-compact-fttp-broadband-ont-and-mini-olt.html
Edit - the link appears to be too long so I've chopped off the https//www  bit.
