Moving config from Hub One to Hub Two
peterholloway
Is it possible to export the config from the older device and import it to the new one. There are a few tweaks I've made that I'd prefer to pass on. Just wondering if I have to do it all from scratch again on the new device?
2 REPLIES 2
Re: Moving config from Hub One to Hub Two
@peterholloway welcome to the forum.
From my understanding it not possible to port a Hub One config to a Hub Two, so you have to start again.
Couple of pointers, the Hub Two only has three LAN ports and it is not possible to split the wireless names which might be important to you. A positive it can operate in 'Bridge Mode' (as a modem only) so if required to can use your choice of router if you have space for two devices or wanting to have a mesh system.
HTH
peterholloway
Thanks Dan, it's more port forwarding and IP address reservations, not super complicated, it would just have saved my some time. I'll just bite the bullet and document the old config before upgrading.
Thanks Smiley
