Many HUB TWO questions
Re: Many HUB TWO questions
@markv
When you connected the DSL cable did the broadband username stay at [email protected]? If it did then it is likely not enrolled on to the management system.
Is it working with your plusnet credentials?
Fixes: 480
@markv wrote:
Looks like I need to wait for a PN Mod to take the serial number.
Just for info, this needs to be picked up by a member of the Plusnet Help Team.
We Moderators are fellow customers who do the job voluntarily.
bobpullen
Fixes: 331
@markv feel free to message me with the hub serial and your Plusnet account username.
When a broadband account is cancelled, the TR069/ACS URL of any associated hub is overwritten, which completely breaks the association with the management platform and prevents firmware updates/remote management.
markv
@Dan_the_Van wrote:
@markv
The username was initially [email protected] - that appeared to Connect but not provide Internet access.
So manually changed to [me]@plusdsl.net + pw and it then connected correctly.
markv
Hi @Baldrick1 ,
I appreciate that, and appreciate the hard work you all do. I said PN Mod as I thought some Mods were Plusnet staff, and that was whom I was sort of addressing.
Apologies for an y confusion.
mark
Fixes: 587
That's what you would expect, the setup user allows sufficient connectivity to contact the management server, but not general internet access. With a router that's active on the management platform , it would automatically pull down the account username/password and configure itself.
markv
Now updated.
Many thanks Bob. Job done 🙂
