Many HUB TWO questions
markv
Currently running a very ancient Draytek Vigor router on my Plusnet FTTC service.
Decided I needed a backup router for when the Vigor dies.
My issued PN hub is the also-ancient Technicolour, so bought a new-in-box PN HUB TWO on eBay.
Seems like a nice piece of kit.
Being paranoid, I would like to force a firmware update, to ensure I've not bought a cuckoo that is phoning home my web traffic (and passwords!).
Q1: Any way to force that to happen? Current f/w is v0.05.03.07154-PN
Very happy that the HUB TWO can be configured with custom DNS (the HUB ONE couldn't be).
One remaining snag; I would like to be able to remotely initiate a VPN connection *TO* the HUB TWO.
Is that possible?
The H2 makes a big deal about being VPN-friendly, but that seems to be from a dumb-consumer outgoing point of view.
I would like to set up an IPSEC VPN host end-point on the H2.
Q2: Can that be done?
Thanks.
Mark
21 REPLIES 21
Fixes: 1,495
Re: Many HUB TWO questions
Moderators Note
This topic has been moved from Broadband to My Router
In answer to your questions
Q1) The Hub two needs to be registered to the TR069 management system against your account to receive updates. It is important you inform plusnet you have this device as it may still be registered to it's previous owner/user and logon as that owner/user.
Q2) The Hub two does not have an inbuilt VPN server, so you'd need to find an alternative method
HTH
markv
Many thanks. how do I register the hub to the TR069 management system?
Who do I PM the hub serial number to?
thanks.
mark
p.s. it was purchased BNIB and didn't appear to have been opened, and had no user customisation, so probably not registered to previous owner.
I know in the past @bobpullen has helped here, but it is not his day job to follow the forum.
Hopefully one of the plusnet staff will see this thread and help
Dan.
Fixes: 585
@markv routers are automatically registered to an account on dispatch. The serial no is scanned and associated with the router order for the account.
You need to wait for one of the Help team to respond to your thread. They will either request a PM or create a ticket to which you can reply
markv
Not sure if I'm 'telling tales' here but..
In the eBay advert, the item was pictured in it's box, with an address label (of the original recipient), but with personal info redacted with a black marker.
When it arrived, there was no such original address label; just a clean, unadorned, unaddressed box.
What does that suggest?
Mark
(awaiting instructions to send serial number)
Fixes: 585
Its a long time since I received a router but IIRC there was a 'sleeve' over the box with address/account details. The sller probably just removed that leaving the basic box.
Fixes: 480
Is this correct?
I’m only questioning this as if a BT Smarthub is used on a Plusnet service then BT still update the firmware despite it very obviously not registered to the original user. I have known them update during the initial boot sequence.
Personally I would configure it to use the correct account and see if it updates. Obviously in the longer term it is very desirable to get the hub correctly entered on the management data base so that it will auto configure after a full factory reset.
Fixes: 585
Is this correct?
TBH I'm not sure. I suspect you're right, that as long as the serial no is still active on the management platform then it will update. In this case the f/w seems quite old , so I suspect its not been used for a while and will have dropped off the system.
@Baldrick1 and @MisterW
Is it not the case unless you remove the DSL cable from the BT Hub while setting up your plusnet broadband account it will keep returning to the BT account ID?
It may also depend on how the CWMP system is configured.
I agree if it has dropped from the CWMP system then it won't matter, but there again it won't update the firmware on booting.
Dan
markv
To be clear, this is a Plusnet HUB TWO, *NOT* at BT hub.
Fixes: 480
@Dan_the_Van
Yes that’s correct. You enter the Plusnet credentials then plug in the DSL cable. It is during the start up period that follows that I have known a Smarthub update its firmware. I’ve also known it take a few days.
@markv
I’m aware that you have a Plusnet hub, However this is a rebadged BT Smarthub 2 with tweeked firmware so am questioning whether they follow the same update path.
@MisterW
Agree, it is very old firmware.
RobPN
Fixes: 15
Mark
@markv
Just to confirm what @MisterW said in post #8 above, I just checked my unopened Hub2 package and there is indeed an address label stuck on the shrink-wrap enclosing the box. Thumbs_Up
markv
Checked this morning hoping it would have picked up a 2AM update, but no change.
Looks like I need to wait for a PN Mod to take the serial number.
