Latest Update Causing Issue
- My Router
- Latest Update Causing Issue
05-05-2018 10:20 AM
I have a continued and ongoing issue with my connection to the router, I have a Hub One.
My lack of connection coincides with the latest update of the routers filmware on the 21st April
Could it be possible this update failed in some way and is causing the issues.
Would it be possible to force an update to my router either re-run the same update or the previous version to eliminate a this as a potential cause
Message 1 of 3
(389 Views)
2 REPLIES 2
Re: Latest Update Causing Issue
05-05-2018 12:45 PM
Could you elaborate on the issues you're experiencing, and what firmware version you're now running?
It is possible to reinstall/downgrade, however I want to be certain it's worth your time.
Message 2 of 3
(349 Views)
05-05-2018 12:59 PM
Moderators Note.
Moved to router board
Message 3 of 3
(338 Views)
