Issues with Hub One Wifi
Arcanum
Hi
I'm having a problem with the wifi on our router.  Most devices work without any problems.  However, we have three devices that just won't connect.
I believe the router is using the latest firmware (which fixed the 5GHz issue)  4.7.5.1.83.8.289.1.3, and the 2.4GHz and 5GHz channels are split, but the devices won't connect to either channel
The logs in the router show repeated 'Client associated' then very quickly 'Client disassociated'.
The devices work with other APs without issues - so it seems to be a weird problem with the Hub One.  At least 2 of the devices used to connect ok until recently.
I'm out of ideas, so any help would be appreciated.
5 REPLIES 5
adamwalker
Fixes: 223
Re: Issues with Hub One Wifi
Hi there @Arcanum, I'm sorry about the issue connecting some of your devices to the router. If you haven't already it would be worth trying a factory reset: https://www.plus.net/help/broadband/router-user-guides/#:~:text=Use%20a%20paper%20clip%2C%20pen,now%...
Let us know how you get on and we can always take a look at replacing it if the issue persists.
 Adam Walker
Arcanum
Hi Adam
Thanks for the reply.  I'll give it a go.
adam945
Fixes: 113
Cheers @Arcanum, let us know hoe you get on. Smiley
 Adam
 Plusnet Help Team - Leeds
Arcanum
Hi Adam
The factory reset seems to have done the trick.
Fixes: 1,665
Glad to see that!
Let us know if there's anything else you'd need help with Smiley
