Issue with Port 80, Hub 2 Router
hodgesteve
I recently upgraded to Full Fibre 900 and changed my netgear router to the Hub 2. I changed my Hub 2 IP range to replicate the old netgear router and inputted all the port forwarding rules used on the netgear to the Hub 2. I run a number of IP security cameras (6) all on fixed IP addresses and to my surprise everything worked OK and I could see all the cameras over the Internet.
After a couple of days one camera dropped off line and when I checked my Port forwarding rules I found that the Hub2 router had allocated Port 80 to the camera causing a conflict to the existing port I had allocated.
My old Netgear router allocated port 80 to FTTP automatically and I expected the Hub 2 to do the same.
I don't want to just delete the port 80 rule against the camera incase I lose Internet access and access to the remaining cameras.
How do I change Port 80 from the camera to HTTP? Advice needed. Thanks
1 REPLY 1
Re: Issue with Port 80, Hub 2 Router
Standard port numbering.
Post 80 *is* HTTP
