Is guest network on 2704N possible?
- My Router
- Is guest network on 2704N possible?
31-08-2019 8:03 PM
I'm setting up my 2704N Sagencom router. How do I set up a guest WiFi network?
I've looked in the normal URL as well as http://192.168.1.254/expert_user.html but can't find it.
Is it possible and if so, how?
Something I read suggested firmware update/upgrade but I can't find anything about doing this either. My firmware: 7.275.11_F2704N_Plusnet
Thanks.
Re: Is guest network on 2704N possible?
01-09-2019 12:07 PM - edited 01-09-2019 12:09 PM
@cassie Welcome to the forum.
Sorry but neither of the Plusnet hubs have the capability to set up a guest mode.
Firmware updates are automatically installed remotely by Plusnet.
- My Router
