Indicator LEDs on Router
willum08
I' ve just received my Plusnet Hub One Router. in the handbook which came with it, there are several references to  Hub Lights but Where are They?  I can't see any LEDs on the front panel or identifications of which is which........
I have not yet  powered the router because my Broadband is not due to go active for a few days yet....
6 REPLIES 6
Fixes: 480
Re: Indicator LEDs on Router
@willum08  Welcome to the forum.
Apart from the main light they are well obscured unless you have a fault, when they will appear on the front.
Strat
Fixes: 565
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
willum08
Thanks for your reply.. much appreciate...
However, the 'Let's get connected handbook is not very helpful...  on page 13 What are my Hub's Lights telling me?
I would have thought that a simple picture pointing out the locations of the various lights would be very useful.... Do I assume that the long 'grey bar immediately below the Plusnet Logo. is the 'Power Light' ? and the other indicators are located in the clear panel below the long grey bar?
Fixes: 480
Yes.
I can't comment on the quality of the documentation, I have never had a Hub One.
@willum08
Everything you need to know about the Hub One is here :- http://192.168.1.254/help.htm#PASS
You need to be attached to the Hub One for the link to work
Dan
See attached for pdf version of help
Talldave
There's a Plusnet Help YouTube channel with setup videos. Documentation that describes lights is here: https://www.plus.net/help/broadband/router-setup-guides/hub-one/
If you want to see the power light, power it up! The Wireless and Broadband lights on the front panel are invisible until they illuminate - off is good!
