Hub2 Hybrid Connect Panel
raymondlan65
Does anyone know why a Hybrid Connect interface panel appears "Occasionally" in the Hub2 Manager?
Just noticed this today.
8 REPLIES 8
Fixes: 476
Re: Hub2 Hybrid Connect Panel
@raymondlan65
As the firmware is a variation of that used by BT I would assume that the firmware is in a screwed up state. Factory reset the hub by pushing a paperclip or similar in to the reset hole. Keep the switch closed until you get a green light then leave it to reconfigure itself.
Fixes: 146
@raymondlan65
It would be interesting to know what the Hub's current firmware version is
To find the version navigate from Home > Advanced settings >Technical log
Firmware version:v0.10.00.04201-PN
Firmware updated:30-Jun-2023   <-- date of last update
I believe 'Hybrid Connect' is 4G broadband failover
Fixes: 578
It is, but its connected via a LAN port to the Hub. I'm wondering if there's something connected that the Hub 'thinks' is a Hybrid device ?
@raymondlan65 what ethernet devices do you have connected to the Hub 2 ?
raymondlan65
Hi @Dan_the_Van
The firmware is v0.10.00.04201-PN the same as you mentioned.
raymondlan65
@MisterW There is only a Netgear switch and that connects to another computer. The Hybrid Connect has permanently disappeared now.
Many thanks all
paul_blitz
Fixes: 4
BT's Hybrid Connect uses an ethernet cabled connection for the initial config, but after that, it can link via wifi... kinda like the initial setup for their mesh disks.
bobpullen
Fixes: 330
Getting off-topic now, but the initial pairing for the BT Hybrid connect can be done via cable or over Wi-Fi using WPS.
Must admit, I've never come across the tile mysteriously appearing on a Plusnet hub 🤨
raymondlan65
Many thanks. It has not reappeared. It was just very strange when it did appear.
