Hub two Router with USB stick for NAS
g6yrk
What is the largest USB stick to use as a NAS ?
3 REPLIES 3
Re: Hub two Router with USB stick for NAS
The USB port on the Hub Two only supports SMB1 which has security issues, is this something you are aware of?
Both windows and Linux system will need changes made to support SMB1
g6yrk
Yes a Know that but what Max USB size
Protech
Seasoned Pro
Fixes: 8
Hub2 only supports FAT32 for USB drives so max size is 32GB if formatted pre WIN11.
This thread maybe helpful
https://community.plus.net/t5/My-Router/USB-Sharing-on-Hub-2/td-p/1887653
You can check out but you can never leave ( easily)
