Hub preset login details can remove?
fishtank
The PN router is sent with user login details preset. Would a factory reset remove those details?
7 REPLIES 7
Fixes: 585
Re: Hub preset login details can remove?
No it isnt. The serial number of the router is registered against your account. The router is supplied configured with a standard setup account, when it first connects with those details , it retrieves the correct account details via the TR069 configuation protocols.
A subsequent factory reset , will return it to the setup configuration and it will repeat the process.
"A subsequent factory reset , will return it to the setup configuration and it will repeat the process"
If a Hub two is factory reset it will be returned to the defaults including the broadband username which is [email protected].
The repeat process would only occur if the HUB is connected to a live DSL or WAN connection, without a live connection it should stay at [email protected]
EDIT: it is worth noting if the Hub is taken to another plusnet users house when connecting it will use the account the Hub is paired to.
fishtank
"No it isnt. The serial number of the router is registered against your account. The router is supplied configured with a standard setup account, when it first connects with those details , it retrieves the correct account details via the TR069 configuation protocols. "
Ahh, I stand corrected. Next question would be: Does an _unused_ router sent back have that serial number and account relationship removed?
Fixes: 585
Yes
Fixes: 389
Yes.
fishtank
Right, thank you. Meant to add for probable reuse for another user.
Fixes: 389
@fishtank In that case, IF they did use it, they would have contact PN and get it associated with their account.
