Hub Two - no 5GHz WiFi
western82
Hi
I just recently got my Hub Two. The configuration is pretty straightforward. The only thing I didn't manage to get working is 5GHz WiFi. I see it turned on in the manager but my devices do not see it available.
I know my devices see 5GHz networks in general since they see a Plusnet 5GHz network from my neighbor all the time.
Any ideas?
Thanks!
5 REPLIES 5
Mustrum
Fixes: 81
Re: Hub Two - no 5GHz WiFi
the Hub2 has a combined SSID, with no separate 5Ghz band.
bobpullen
Fixes: 331
How are you determining that your devices don't see it available? The Wi-Fi network name for the 2.4GHz and 5GHz networks is common.
What devices are we talking about?
western82
Oh I see. So the question is how to choose between 2.4GHz and 5GHz WiFi in this case? I'm trying to connect using Windows 11.
Or "no separate 5Ghz band" means I can have 2.4 or 5Ghz but no both at the same time?
Fixes: 585
You don't choose, the router and the connecting device use 'Band steering' to decide the best connection
https://www.devolo.global/glossary/band-steering
Fixes: 480
@western82
You can leave the connected device to choose for itself. If it's a dual band device it should automatically use the best.
Unfortunately, unlike the older Hub 1, you can't split the bands on a Hub 2.
Another option: https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Separate-Bands-with-a-Smarthub-2-or-Pl...
