EdgeRouter 4 Poe DNS issues with Fibre and Openreach ONT
JohnD76
I have activated my Plusnet today having moved from SKY. I am expecting that I can simple use the Edgerouter 4 connected to the Openreach ONT, without needing to the use the plusnet router or a Draytek.
I appear to be connected to the Internet but cannot resolve anything for DNS issues.
Contents of PPPoE log from Edgerouter is:
Mon Sep 18 12:15:19 UTC 2023: PPP interface pppoe0 created
Mon Sep 18 12:15:22 UTC 2023: Stopping PPP daemon for pppoe0
Mon Sep 18 12:15:23 UTC 2023: Starting PPP daemon for pppoe0
Connected to MAC via interface eth0
using channel 1
Renamed interface ppp0 to pppoe0
Using interface pppoe0
Connect: pppoe0 <--> eth0
sent [LCP ConfReq id=0x1 <magic 0xf1672b4e>]
rcvd [LCP ConfReq id=0x2 <mru 1500> <auth chap MD5> <magic 0x254c1901>]
sent [LCP ConfAck id=0x2 <mru 1500> <auth chap MD5> <magic 0x254c1901>]
rcvd [LCP ConfAck id=0x1 <magic 0xf1672b4e>]
sent [LCP EchoReq id=0x0 magic=0xf1672b4e]
rcvd [CHAP Challenge id=0x1 <>, name = "acc-aln1.l-ri"]
sent [CHAP Response id=0x1 <>, name = "[email protected]"]
rcvd [LCP EchoRep id=0x0 magic=0x254c1901]
rcvd [CHAP Success id=0x1 "CHAP authentication success"]
CHAP authentication succeeded: CHAP authentication success
peer from calling number MAC authorized
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0>]
rcvd [IPCP ConfReq id=0xaf <addr 172.x.x.x>]
sent [IPCP ConfAck id=0xaf <addr 172.x.x.x>]
rcvd [IPCP ConfNak id=0x1 <addr 91.x.x.x>]
sent [IPCP ConfReq id=0x2 <addr 91.x.x.x>]
rcvd [IPCP ConfAck id=0x2 <addr 91.x.x.x>]
Script /etc/ppp/ip-pre-up started (pid 3150)
Script /etc/ppp/ip-pre-up finished (pid 3150), status = 0x0
local IP address 91.x.x.x
remote IP address 172.x.x.x
Script /etc/ppp/ip-up started (pid 3202)
Script /etc/ppp/ip-up finished (pid 3202), status = 0x0
Excerpts from ER config showing Eth0 interface:
firewall {
all-ping enable
broadcast-ping disable
ipv6-receive-redirects disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name WAN_IN {
default-action drop
description "WAN to internal"
enable-default-log
rule 10 {
action accept
description "Allow established/related"
state {
established enable
related enable
rule 20 {
action drop
description "Drop invalid state"
state {
invalid enable
name WAN_LOCAL {
default-action drop
description "WAN to router"
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
options {
mss-clamp {
interface-type pppoe
mss 1492
send-redirects enable
source-validation disable
syn-cookies enable
interfaces {
ethernet eth0 {
address dhcp
description Internet(PPPoE)
dhcp-options {
default-route update
default-route-distance 210
name-server no-update
duplex auto
mtu 1508
poe {
output off
pppoe 0 {
default-route auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
mtu 1500
name-server none
password redacted
user-id redacted
speed auto
any assistance is welcomed.
Thanks!
9 REPLIES 9
Fixes: 479
Re: EdgeRouter 4 Poe DNS issues with Fibre and Openreach ONT
@JohnD76   Welcome to the Plusnet Community Fora.
Why not start with connecting your Plusnet hub? This will make it easy to determine whether your service is yet up and running (this can take up until midnight for Plusnet to fully activate the service).
Once a running service is confirmed, look at swapping to your favoured device.
Fixes: 581
@Baldrick1 the connection is live , its authenticated and got an IP address and gateway via pppoe
@JohnD76 I'm no edgerouter expert but this
name-server none
In the pppoe config don't look right !! You either need to use the ISP provided ones from the pppoe or you need to set some manually...
JohnD76
Hi Baldrick,
I spent most of the morning tethered from my phone whilst trying to get the ER working and have relented and connected the PlusNet router in and it is working well.
I have noticed the way the dns servers are set up in the plusnet router and will try that once I have logged off from work, but I have tried using the google dns servers and this also didn't work. 😞
JohnD76
Hi MisterW,
Thanks for the swift reply.
I was running name-server auto previously and also configured it to use the google dns servers but got the same results, so something is amiss.
My sky fibre was set up and working without issue, but this needed ipv6 prefix delegation, so I have removed this from the config, removed the ipv6  firewall rules and added a pppoe interface which is connected to eth0. So there have been a few changes.
The connection appears to be established, but the dns issue is the next hurdle to get over....
I will keep trying and report back.
Fixes: 581
The Plusnet router will ALWAYS get the Plusnet DNS servers from the pppoe negotiation. The DNS server configuration settings on the Hub 2 ONLY configure which DNS servers to supply to LAN clients via the DHCP lease.
By default it will supply its own lan address ( 192.168.1.254 ) and it (the Hub 2) will forward DNS requests to the Plusnet DNS servers obtained from the pppoe. If you specify DNS servers , then the LAN clients will use these directly and bypass the router DNS forwarding.
JohnD76
I have 4 DHCP scopes on my edge router which use differnet dns servers based on the usecase, kids, parents, guests and IoT, and 2 vlans.
The pools have not changed for years and the clients are still getting the correct assignments and dns servers, but for some reason they are unable to resolve anything on the internet connected via the ER (which was working with SKY). I am a little reluctant to blat my ER config, since it has taken a while to get it to the stage and it has been working faultlessly for years.
I might see how I can export and reimport it if needed.....
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Router
JohnD76
I have exported the config and run the basic wizard for PPPoE and this is working so there is something in my config (dns or lack thereof) which is causing the problem.
I am going to inspect the configs and get it working with my setup.
Thanks all, I will report back......
JohnD76
I have reviewed my old config and the new bare bones basic pppoe config through the wizard and spotted the problem.
The services NAT config was sending all traffic to the eth0 interface still and not the newly created pppoe0 interface I had created....
Thanks for all the advice and pointers.
