Hub Two WDS Management Settings; Using ASUS router as repeater
j2cuba
Hi.
I am trying to use my ASUS DSL-AC68U as a wireless repeater for my new Hub Two. I will be using it to repeat wirelessly, not using LAN.
In going through the process on my ASUS router, it advises that I need to "open the remote AP's WDS management interface and key in this router's MAC address"
I can't find in the Hub Two router management where I find WDS management.
Does it have this functionality?
Thanks for any help anyone can offer.
Tags (1)
4 REPLIES 4
Fixes: 585
Re: Hub Two WDS Management Settings; Using ASUS router as repeater
Pretty sure it doesn't.
j2cuba
Thanks, appreciate your quick reply.
Does this mean the Hub Two can't be configured to be used with any wireless repeaters, or is it just a problem if using a second router in repeater mode do you know?
Anth22
Don`t believe so, or you would need to look for a router not expecting WDS Management. Could possibly look at wifi extenders that don`t require WDS Management.
j2cuba
OK, thanks, appreciated.
